Biggyniner wrote:
fourthclassC wrote:
Howdy I want to reiterate my suggestions. The resolution for me was the ignition control module on the inner fender
I will be replacing mine this week. I will let all know of the results.
CN
So I replaced the ignition module... Did not fix my issue. I pulled the PCM/ECU and discovered I had a re-manufactured one! When I opened it I realized that whoever "refurbished" it did not put the correct capacitor in. There are supposed to be 2 47uF capacitors and 1 10uF capacitor. All 3 of mine were 47uF...
Pretty sure this is my issue. New capacitors are arriving from Amazon tomorrow and I will let you all know if this finally solves my issue.
Video showing capacitor change.Just so you know the ignition module may still fix your issue. O'Rilley had mine for ~40.00 bucks
