Again Thanks to everyone for their input. I went and test drove the 2 units today. I was not able to get them to a scale, they are calling for sleet today so we just did a 12 mile loop with about 6 miles of highway.
The Chevy was very nice to drive and it surprised me. I had a comfortable conversation with the salesman even while accelerating onto the highway. The transmission shifted smoother than my Dodge 1500. It did ride soft for a truck and the steering was very precise and tracked well. I had to adjust the seat forward so there was about 5" behind it for reclining. The interior fit and finish of the cab was a bit thin, the plastic just was not very heavy. The road noise and wind noise were not bad but I know tires can have a big bearing on this. It had General tires and I dont know their reputation.
The Ford at idle was smoother and quieter but the minute I hit the gas it was considerably louder and I could tell the rear was geared lower because I found myself stepping harder on the gas to get up to speed. It was not less powerful but seemed to need more rpm to really get moving. The ford motor has more growl and we had to pause our conversation during heavy acceleration. The Ford steering needed more attention, I first noticed it when I hit a pothole that I had hit in the chevy as well. The ford made a move to steer in that direction but the chevy went straight through. The Ford accelerated just as fast getting onto the highway but again it was much louder. It did ride noticeably firmer than the GM and the road noise was a bit higher but it was on Michelin tires and they may have been the culprit. The tranny shifts very positively. I had to adjust the seat forward just a bit from all the way back but not far enough that I could recline the seat back more than a inch. I did notice the steering was not as bad as some have described, even with a stiff intermittent cross wind but I did notice that it needed constant minor correction. It seemed the wheel had a larger loose range before you felt steering feedback and was easy to over-correct. I am sure you would get use to it, I had a Ford Windstar that was the same way and the only time I was uncomfortable with it was in narrow lanes or in a tunnel because you worried about drifting to close to another car. The Ford interior was a cut above the GM. Thicker plastic and more solid feeling and a bit better layout.
Anyway I decided to go with the Chevy. I really wanted the Ford because of the higher tow rating and its reputation for being pretty much bullet proof with a long track record. But in the end I plan on doing more touring than long camping and the better comfort and low noise and longer warranty won out. The dealer was real nice and gave me the same price without any more negotiation.
