T18skyguy wrote:
...You eat up more in gas with the older transmission, 5 speed probably in the middle I suppose. It's not just the final ratio's that's important...
Might be able to help with that... In the Muscle Car Days, the transmissions that could handle Big Block/Trick Car/Heavy Foot were GM's TurboHydramatic 400, Chrysler TorqueFlite 727 and Ford's Cruise-O-Matic C6.
4R100 was the final derivative of C6, with the E4OD derivative in between. Snippets from Wikipedia:
First, a compliment to the C6: "widely used in off-road applications due to its reputation of being nearly indestructible"
Then, a fundamental C6 design drawback that bears T18's remark out: "a reputation of greatly reducing performance as well as fuel mileage, due to the amount of power it requires to operate"
Strong/Hungry Heritage in E4OD: "C6 core components were used to build Ford's first electronically controlled automatic transmission"
Then the 4R100: "this new transmission was the last rendition of the C6"
From owning and loving two Ford based Class C's, the first a 24-ft on an '83 E350 with 450 and that C6... Here are j-d's
TIPS FOR CO-EXISTING WITH 4R100:
1. GET OVER IT: We all hear "It's the Nature of the Beast." Well it IS a Beast and it has that C6 Nature. Still, behind the V10, 4R100 drags our 31-footer around at 10 MPH faster, 1 MPG better, longer, higher, wider and 3000# heavier...than the 460/C6 with the 24-footer
2. UNDERSTAND IT: 460 was a Lugger and C6 didn't have lockup let alone OD. V10 Powertrain Control Module wants to let'er rev, and commands the 4R100 to downshift to allow those revs.
3. ACCEPT IT: "Hi, I'm your 4R110, you had a Question?" Answer is always "Downshift!" Knowing this... Anything involving Cruise Control is downshift for any reason any time. You can accelerate a little with the pedal and re-set your speed. Hit "Accel" and it's downshift. Most "hills" on I-95 are simply overpasses and 4R will downshift on every one in Cruise unless I nudge speed up (with PEDAL, remember) in advance.
4. LET IT WORK: I was under driving the V10/4R package! Best results are simply NOT "just after it hits OD" or "slow lane" or "under 60." If conditions allow, it's around 65 MPH and that's good for a MoHo. Many less PCM-commanded downshifts and MPG no worse than the 55 I drove the 460.
5. WORK WITH, NOT AGAINST: Really hilly? That's what the OD OFF button's for. It ain't gonna blow up or wear out. C6 ran like that its whole life. Torque will be there. It'll climb, and unlike 460 it won't heat up.
6.GO RETRO: How were you taught to drive? I was taught to Look Ahead, to Anticipate, to Plan. Definitely NOT to hold the wheel while some RADAR said Stop or Go. ALL our vehicles had the C6 Nature and we drove accordingly. Speed up before a grade and know you'll slow before the crest.
7. ENJOY: The Drive is Part of the Fun! When we clear out of Flat Florida, the road curves, rises and falls. My vigilance goes up, but I'm comfortable. I sit straighter as tension melts away. I drive with the pedal and work within a speed range. I'm in the driver seat and the PCM is helper not master.
