I crawled under the front end of mine to look at the front sway bar, and the rubber grommets that are pressed into the I beams are pretty much toast, but the chassis is a 2006, so I wasn't surprised. I guess I will have to spring for the hellwig bar for the front. I see they are around 225.00..... I can't imagine that a Ford dealer would charge less to fix the stock bar grommets... I might also get a new steering damper while I am at it. But there is no way I can do the front shocks... The rear ones, sure, but not the front
