j-d wrote:
Might rain, so I got the cardboard out, slid under with a handful of sockets, and here are the E450 sizes, through Chassis Year 2007:
Front and Rear Sway Bar Center Bushing Brackets: Metric 15MM
All parts furnished by Hellwig: SAE 3/4"
There isn't an SAE size that'll "work as 15MM" so you need that specific socket. Standard depth is fine.
You can get away with 19MM for the 3/4" but the socket should be Deep.
I always get Six Point Sockets.
So you'd need a Ratchet, two Sockets, and a Wrench.
Wrench can be an Open End, Combination (box/socket end plus an open end) or an Adjustable. 8" would be nice, but a 6" will open to 3/4".
Again, suggest 1/2" drive for the sockets. I don't like the fastener diameter much bigger than the square drive size of the socket set. The 3/4" tools will be working 1/2" fasteners, and the 15MM is driving screws that are about 7/16".
Footnote: 2008 and newer use two different sizes on the front bar center brackets, the 15MM and something larger. Common next larger'd be 17MM but I don't have a vehicle to check that on.
EDIT: Looked at the OEM rear sway bar end links I removed to install the Hellwig bar. The 3/4" or 19MM socket will remove the frame end. The bar end is 14MM but your 15MM socket'll catch it if you get a six point. Or if your open end wrench is an adjustable.
Thank you for your over and above help. I have tinkered with my motorcycle (oil change, rerouted electric lines so they weren't under the gas tank, changed spark plugs which required some engine mount stabilization, etc). I have a full set of metric and English sockets along with a torque wrench and open ended wrench. My sockets are 6 points so they should grip just fine.
It sounds like a "simple" remove the old sway bar and install the new one in it's place. I will tackle the issue after our Labor Day weekend trip but before our trip to Florida in July. Got to come up with the funding first. Spending way too much right now on the rig.
