2Bargos
Dec 26, 2013Explorer
dakdave wrote:
On the starter there is a smaller wire usually a push on spade terminal adjacent to the battery cable.
Make sure this connection is good.Ford had a lot of problems with corrosion on these terminals.
Many replacement starters come with a wire soldered on that you splice to original wire.worth checking
dave
The spade terminal is the key switch wire.it activates the solenoid.I have never seen one with a soldered wire on it. the earlier ones used the spade and around 96 and later ford switched to a threaded terminal.
Because of the location of the solenoid on ford engines they are prone to corrision.I would check my connections here first.
38,769 PostsLatest Activity: Mar 31, 2026
