theoldwizard1
Sep 03, 2018Explorer II
A small amount if water ingestion is not a problem, but a large amount can cause catastrophic engine failure. Some intake systems allow water to pool in an area and then the engine gets a big slug when you go around a corner.
If the area where it is pool is in FRONT of the mass air flow sensor, simply drill a hole in the low spot.
38,766 PostsLatest Activity: Jan 10, 2026
