kmb1966
Sep 03, 2018Explorer
It made the SERVICE ENGINE LIGHT come on. Scangauge returned a code P0103 which refers to the air flow sensor detected a problem. It was very wet inside the area where the airfilter is located. Very frustrating since I have performed the modification that Ford says to do. The air intake is somehow able to suck in water even with the modification. I am afraid of drilling a drain hole as suggested because I am concerned it will suck in water thru the drain hole instead.
38,766 PostsLatest Activity: Jan 10, 2026
