Hpymils
Aug 05, 2015Explorer
Ford Steering
Is the problem with Class C Ford 26 feet and longer caused by the over hang behind the rear wheels causing over and under steering?
Beverley&Ken wrote:
plus one on checking tire pressure and having it set according to the load each axle is carrying. On ours if the front axle pressure is set to max sidewall rating 80psi, driving is a nightmare, reduce to 65 psi, Michelin recommend 60 for our load and driving is easy.
Ken
