wincrasher65 wrote:
Transit will be a very popular choice, but I think the rear wheel drive layout will cause some issues.
May effect room underneath for RV equip and tanks. Also big torque losses thru that configuration compared to the front drive of the RAM. So drivability may be a factor when people are test-driving finished RV's.
But they do have a longer version - so at 24 feet, you can make a more spacious RV.
The way I see it - the market will segment into 3 parts - Sprinter will be premium. Transit will be the mid-market filling in as an alternative to Sprinter on the high end. Promaster will be the economy end of the market.
But which segment will be larger? My guess is economy.
The longest Transit will only be 22 feet not 24 feet. It is much closer to size to the older 5 cylinder pre-2007 model Sprinter. That was a popular size. The Sprinter will still own the the maximum size and payload. The Promaster has one plus in size in it being wider than the Transit and Sprinter but its length relegates it to pinched size comparable to the Roadtrek Agile and Pleasure-way Ascent models.
As for the rear wheel drive it is just the opposite. In order to have a drive train you have to have the higher floor thus more capacity underneath for tanks and such. That is the Achilles heel of the Promaster for RV conversion which has led to smaller tank capacities and make do fixes like putting the water tank inside the van inside an ottoman and having a convoluted waste system. The Ford Transit makes better sense for Class B conversion, IMO.
The argument for the Promaster has been its RV popularity in Europe. But Europe doesn't use Class Bs the same as American tourers driving long distances with more internal capacity reliance and in more extreme climates (no AC for instance in Europe.) Economy is the Promaster's redeeming factor. For that reason I suspect it could be more popular with DIYers because they generally go that route to save money and seem to put up with fewer amenities on the average. Also, building on top of the floor is a lot easier than under for a DIY. The Promaster could serve well for non-retired, families, dual use, weekenders and limited vacationers and singles. I think it might prove too limiting for retired couples and extended use tourers. The problem with the targeted group I think could have appeal for Promaster is generally its too big an expense at any price when a $10.000 poptop trailer will do for them.
The Ford Transit will be popular for those that desire to stay under 22 feet vs. Sprinter at 22'-9" and 24'-1". The pre-2007 Sprinter was 21'-8". The Ford Transit should be a very versatile size without much sacrifice in design for what is expected in a B.
