Lumpty
Dec 29, 2020Explorer
The 2v V10 got the PI heads that made a bit more power (305/310hp depending on chassis compared to the original 275hp) and had more spark plug threads 2003 and later. That engine was just phased out of Class C's this year; the 3v heads were too big to fit in the Econoline doghouse and cab opening. The 5R110 trans replaced the 4R100 in 2005, with the 6R140 intro'ed in Class A's and C's only a few years ago.
I have 80k miles on a 2010 E450 V10/5R110 chassis. The only things done to the drivetrain have been oil changes, a tensioner and serpentine belt, filters, trans fluid change and, and recently, plugs and coils (that was an ugh! job - 6 hours and every 1/4" and 3/8" extension, wobble and universal that I had got used!). I did have the electronic throttle sensor at the pedal go bad 3 years ago at 48k miles, but that was a fluke failure.
This engine though, like the GM 6.0 and now 6.6 gas engines, needs RPM to make power. Mine will easily maintain 65-70mph in all terrain, but with the E450's 4.56 rear, needs a 5-4 downshift, which puts the V10 at 3800rpm. The engine doesn't care, but the typical driver used to big-block torque at lesser twist needs to adjust their expectations.
