Farmhills53565's avatar
Dec 28, 2020
Ford Triton V-10 Info Request
The question I asked the other day helped me and as much as I am liking the idea of Workhorse chassis with the 8.1 Chevy and the Allison, I found out that not all 8.1 drive trains have the Allison transmission. That said if I start looking at the Ford V-10 as an option, is there a certain year range, chassis, or other specs that make one choice better than the other. We are looking for a Class A about 30 foot long. Did they only use one transmission behind the V-10 or did they use a lighter trans in a lighter RV? If they used different transmissions how do I tell which one an RV has?
  • The V-10 with 3 valve and 5r110 trans is rated at 362 HP and 475 ft. lb. torque.
    The V-10 with the 6 speed trans was chipped down to 345 HP.
    The 5 speed is the same trans as the 6 speed but the 5 only uses 5 speeds depending upon the ambient temperature. It will shift 12346 or 12356.
    The better chassis are the 24,000 lb. or the 26,000 lb. with 22.5 tires.
  • DrewE's avatar
    DrewE
    Explorer III
    The transmissions (and engines) varied by year but not really by chassis rating. The axle might be different--I'm not sure on that. In general, the Ford transmissions are pretty solid and reliable if not overly abused.
    There are three main transmission variants you might find: the four speed 4R100, the five speed 5R110, and the six speed of the last few years (the designation of which I don't know offhand--6Rxxx I suspect). The five speed can be differentiated from the four speed by the button on the end of the shift lever: on the four speed, it's for "overdrive off" and labeled as such, while for the five speed it's "tow/haul." Overdrive off, on the four speed, does exactly what it says; it's like shifting from overdrive to drive on vehicles that have those two settings for the transmission. Tow/haul, on the other hand, doesn't lock out any gears, but instead alters the shift points and timing and such to better work with heavy loads, including automatic downshifting for engine braking on downhills. I think it's a good thing to leave engaged all the time assuming you have it.
    In terms of the V10 engine, there is one main upgrade (the two valve to three valve head, with a significant increase in torque and power) as well as various more minor improvements over time. The three valve version was introduced in 2005, it appears.
