timmac's avatar
timmac
Ford V-10 Techs Needed, Diagnos My Erratic Coolant Temp
OK I just went on a short trip out of town on my 08 Bounder Ford V-10, went to Laughlin NV and on the way back up that very steep climb out of Laughlin my trans was searching for gears since I was pulling my Jeep and Boat I decided to put the trans in 3rd on the shifter column and just cruise at 45-50 mph up the hill at about 4500 rpm's, I have never locked the trans in 3rd gear before just decided to try it today and about 4 to 5 minutes up the hill a beeping noise was coming from my dash says check gauges and my engine temp was at max in the red zone, as I slowed downed I shifted trans back into the drive selection and as RPMs went down the temp gauge moved back to the normal range in 1 second, yes it went from max hot to normal temp that fast, I dont know how fast it climb in temp did not notice that part.
So what the heck happen, I did drain my radator about 2 months ago and did test drive than but this was the 1st time out since fluid changes, I did check my radator fluid level at the next stop after this happened and all was fine and as far as I could tell my motor was never hot but the gauge said max hot.
So did running in 3rd gear do this OR did I have a air pocket stuck in the cooling system or what..
Yes its strange what happen but I have never seen a motor cool off in 1 second.
:C
