JoeH
Dec 13, 2015Explorer III
Johno02 wrote:
Check the expansion tank carefullly. It probably wasn't included in the pressure check, as it is not designed to be pressurized. Mine had a small crack, which allowed the excess AF to leak.
The V-10 expansion tanks is indeed pressurized. The cap is much like a radiator cap and releases pressure when the threshold is reached. The tanks are prone to cracking as is the pressure cap. Your pressure test should have turned up a crack in the tank.... did they check the cap ? When you have a chance, you should replace the spring clamps with worm clamps as the spring clamps can break/loosen up at the most inopportune time.
