donfrump
Dec 14, 2015Explorer
Sam Spade wrote:donfrump wrote:
They do not use E series for Class A MH they use the F53 systems
The vapor and water upon startup is condensation Normal! nothing more nothing less
Oops. Lost sight of the sub-forum this is in.
You can't, however, make a flat statement about vapors/smoke at startup because it depends on exactly WHAT it is and how much.
An engine with bad valve guides usually will drain oil down into the cylinders when it's off and puff smoke for a few seconds on startup. Most people can't tell water vapor from smoke just by looking.
What I meant was that all vehicles unpon start up have water/condensation and vapor
second off it a 2015 so I assume its still very low miles
ON RE reading OP notes I read this
The only white smoke occurs on startup until condensation in exhaust clears(couple of minutes).
Now I ask the the OP ? Is he sure it gets real white smoke for 2 minutes? every time? no matter the outside temperature
If so then I concede he may have a internal leak for sure
but as said tail pipe vapor/condensation is normal on all vehicles
