youracman
Jan 28, 2020Explorer
IAMICHABOD wrote:
Just get Set Of These and have them installed and all your problems will be solved. Long lasting,mine have been over 10 years,and it will make your tire pressure checking fast and easy.
Excellent advice. I got mine at a different source, but your best price is here: yourtireshopsupply.com I haven't had mine installed but a couple of years now, but zero trouble; and I can check my tires without even kneeling down! They will come with stabilizers for the long (inboard) dual so no worry about about wobble/vibration when adding TPMS sensors onto the end of the stem.
Les Schwab charged me about $80 to install IIRC. They said it is fast/simple to do because they only have to "break the bead" to install...... no need to demount the tire from the rim. A shop that does lots of truck tires is the place to go IMHO. I do use Discount Tire for my car(s) but for sure not my MH.
For the inner dual at least, it is not usually possible to spin balance because of the length of the stem; I installed Centramatics at the rear, but there are other options, of course.
Good luck with the fix, and safe travels to ya.
