othertonka
Jan 06, 2014Explorer
SuperDutyFiver wrote:
If I remember right from an older thread about this if it's not on the column it will be up there some place-maybe even tied to the front wall or bracketry holding up the dash. Usually either the turn or 4 way still flashes, maybe you can stand on your head with a flashlight and track it down by would before you tear off the covering?
I believe the OP is asking where the 4 way "Switch" is located. It sounds like you are describing where the "flasher" is located. the switch would not be someplace where you had to stand on your head to find!!!!!!
38,766 PostsLatest Activity: Jan 10, 2026
