JohnnyT
Oct 15, 2013Explorer II
Jacks not a problem unless the pads stick to the ground. So have a barrier between the bottom of the jack pads and the ground.
In terms of the slides... slide operation is not a problem unless the seals have moisture on them and decide to stick to the sides..
The other issue relative to really cold weather with slides out is that the slide itself will not be as insulated on the top and bottom as the rest of your motorhome so leaving the slides in will present less challenge for your furnace to keep it comfortable.
JohnnyT
JohnnyT
38,766 PostsLatest Activity: Jan 10, 2026
