We are in NC and will be leaving for FL sometime around Christmas. Our forecast is for some mid 20 degree weather next week. If I run the furnace during these cold days will that eliminate my freeze ...
You can protect the inside pipes by running the furnace, but unless you have a heated wet bay, the pipes outside the rig will be exposed. You might be able to just put a heat lamp in the wet bay to get by the few nights we'll have below freezing temps, as long as there are no pipes/lines under the rig that are exposed.
