We are in NC and will be leaving for FL sometime around Christmas. Our forecast is for some mid 20 degree weather next week. If I run the furnace during these cold days will that eliminate my freeze ...
Just unhook the outside water source and operate off of on board tank. Dump a little pink stuff in the drain and toilet to keep holding tank from freezing. If you are warm inside you will most likely not freeze pipes but light bulbs are a good idea. A remote thermostat in wet bay may give you peace of mind.
