We are in NC and will be leaving for FL sometime around Christmas. Our forecast is for some mid 20 degree weather next week. If I run the furnace during these cold days will that eliminate my freeze ...
As mentioned, keep your fresh water tank filled and an incandescent bulb in the wet bay compartment. Since you will be there, if the weather gets worse you can deal with it then. Reports now indicate that this is a quick dip down and then temps return closer to normal after a few days.
