jonlin
Dec 05, 2016Explorer
freezing weather
We are in NC and will be leaving for FL sometime around Christmas. Our forecast is for some mid 20 degree weather next week. If I run the furnace during these cold days will that eliminate my freeze ...
mikestock wrote:
I have been using the pink stuff for 20 years. Last year I bought a small air compressor that I can regulate to 50 psi. Now, after draining the tanks and bupassing the water heater, I hook it to my water inlet and go from point to point, allowing the air to blow through until there is little or no water coming through. I still use the pink stuff in the traps and run it through my washing machine pump and don't use it until warmer weather.. I disconnect and drain the ice maker.
It is so much easier than the pink stuff and if i decide to make another trip it's easy to do it again.
As for the wet bay: I run one of these little things on low (175 watt) setting.
