fairway2002's avatar
fairway2002
Freightliner Airbag replaced. Now not level
I had a front airbag go bad. Started leaking and would not air up. Replaced (very easy) and now that side is 1.5 inches lower. There is only one leveling valve on front. Do I sim or replace other side? 6 days, 150 miles out of warranty. They are $300 a pop.
Thanks
  • MrWizard wrote:
    i'm only guessing
    but the New one maybe stiffer, the old may stretch more when inflated with the same pressure
    i think i would replace the other old one with a new one, keep it for an emg spare
    I just did exactly this. ^^^^^^^^^^ I blew a hole in a front air bag and I know they are at least 9-10 years old so I wanted them to be the same. I have the old one in a bay as an emergency spare.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Side to side is controlled by the 2 rear ride height valves. Adjust the rear one on that side.
  • Since you have a Freightliner chassis, give the helpdesk a call. It's free. They will need the last 6 digits of your vin number.
    1-800-FTL-HELP
    They were very helpful to me on several problems.
    Fred
  • i'm only guessing
  • Yes it definitely had a leak.. I could feel the air coming out. The new one was the same part. But new one was firmer.
    Thanks
  • On my Alfa 36 foot RV they moved one rear valve to the front. 2 on front and 1 on rear.
    Had my Itasca Ellipse at Freightliner in S.C. this year for front end alignment and the right front is still higher than the left. It causes no steering or driving problems.
  • Are you sure the bag had a hole? The ride hit valve can leak air.
    I think the front one controls ht and the (two) rears control side to side.
    My front failed and wouldn’t work for 10-15 minutes and if I remember, no bags inflated until the front opened.
    Hopefully somebody that knows what they are talking about will chime in.
    So you replaced the air bag, right?
