Rebel4x4's avatar
Rebel4x4
Freightliner Brake Controller Harness??
Does anyone know where to find the controller harness/pigtail to plug into the chassis wiring? I got a part number from Freightliner and the only place I can find it is through a Freightliner dealer for $140, yes that's one hundred forty.
I've checked Hopkins, Curt, and Tekonsha with no luck. I hate to cut the factory plug off to splice my controller in.
Thanks for any help.
  • I've been communicating with Caleb at eTrailer. I don't know your Freightliner chassis model number, so I'm kind of stuck. I'm sure you know your chassis model number, so you can contact Caleb yourself: [email protected] or 1-800-298-8924 ext. 79376. He is very helpful and responds quickly to emails.
    Pat in Menifee, CA
  • Those are the things you look for BEFORE you buy the truck.
  • I just spliced into mine, not a big deal at all, especially for $140. Personally I think that it is atrocious that Freightliner doesn't have a built in unit standard just like most pickups do these days. Part of the reason I feel that way is that I had a terrible time finding a place to put mine. Finally ended up on the far left top side of the dash which is farther away than I would like. For $140 they should include the controller and mounting. For that matter, I am having the same problem with mounting a GPS and they should know that virtually everyone that buys one of these rigs wants a dash mounted GPS. While on the subject, controls for the wipers, lights and radio put within reach would be great.
  • PCarnathan wrote:
    Rebel4X4 wrote, in part: "I have found the connector under the dash."
    You're way ahead of me when I was in your shoes! I just asked eTrailer for the part number for the harness they sold me last year. When I get it I'll send it to you.
    Pat in Menifee, CA
    Thanks Pat
  • Rebel4X4 wrote, in part: "I have found the connector under the dash."
    Pat in Menifee, CA
  • I have found the connector under the dash, I'm trying to locate the pig tail connector that plugs into the under dash plug. No one seems to have one for Freightliner.
  • You don't have to cut the controller end off. Use the "piggy back" type connectors and splice it in. No cutting.
  • I contacted http://www.etrailer.com I received a response very quickly and they gave me the part number for the harness. I bought the controller there, too. I was unable to find the pigtail under the dash of my RV so the local RV shop charged me a half-hour of labor to install the brake controller for me. Money well spent, in my opinion.
    Pat in Menifee, CA
  • Mine is dead center on top of steering column.
