rdhetrick wrote:
msmith1199 wrote:
The code worked and got me into diagnostics, but I dont have a menu option for odometer anyplace. I found an owners manual online for the Freightliner MMDC but mine doesn’t have all the screens as the one in the owners manual. The literature said Freightliner came out with it in late 2004. May Motorhome is a 2004 and the LCD readout on mine looks different than the one in the manual. I don’t know if I possibly got an earlier version or what is going on with it. Per the manual in the regular menus you are supposed to be able to read the odometer and the tripometer. I only have the tripometer in the regular menus. Guess I’ll try calling the company that made it unless you have any different ideas?
I just checked mine, first Service, then diagnosics, then sender, then scroll down a bunch.
Okay, I finally found it. It took a while and I’m not sure how I actually found it, but hopefully I can do it again. I had to switch the Service Menu on the first screen to RAW is what I think it said, then it gave me a different display of menus. I found one that said ODO Diff. The top number shows 38469.9 mi. Then under that is 5262.0 mi. That bottom number matches the current reading on the odometer. So now the only question is do I add 38469,9 to the bottom number to get total miles, or is 38469 the total miles? Based on what I know of past miles at the time the odometer reset, I was guessing I had about 45,000 miles on it. So adding them together gets me close to my estimate.
