msmith1199's avatar
msmith1199
Explorer II
Jun 01, 2020
Freightliner Odometer
I have a Tropical on a Freightliner Chassis. Twice now my odometer has reset to 0 when the main chassis batteries had died. I know there is a way to get the real miles out of the ECM. Has anybody done it and do you know what you have to get to get the true mileage?
  • msmith1199 wrote:
    The code worked and got me into diagnostics, but I dont have a menu option for odometer anyplace. I found an owners manual online for the Freightliner MMDC but mine doesn’t have all the screens as the one in the owners manual. The literature said Freightliner came out with it in late 2004. May Motorhome is a 2004 and the LCD readout on mine looks different than the one in the manual. I don’t know if I possibly got an earlier version or what is going on with it. Per the manual in the regular menus you are supposed to be able to read the odometer and the tripometer. I only have the tripometer in the regular menus. Guess I’ll try calling the company that made it unless you have any different ideas?
    I just checked mine, first Service, then diagnosics, then sender, then scroll down a bunch.
  • rdhetrick wrote:
    This is a very common problem on Freighliners with the MMDC. If you've got the MMDC, go to the "diagnostics" menu, the password is 8127. Scroll down to an item that says "odometer compare" or something like that. It will show you what what is recorded in the ECU and the IP.
    Most say Freightliner won't do anything about it. Mine odo dropped to about 62k from 115k a few weeks ago. I'm not going to do anything about it except disclose the real number if/when I sell the coach.
  • I had a fault with a rear air tank sensor (micro-computer) and when I picked the rig up from Freightliner in Sacramento, CA I found the odometer has 43,000 less than when I took it in. The tech couldn't explain why it happened, but stressed that federal regulations prohibit adjusting odometers. He was able to get the correct mileage from the main computer and deducted the present odometer reading from it and posted the difference on the entry doorpost. It is frustrating because I understand why no messing with the odometer, but, gollie, I wanted to PUT 43,000+ miles back on, not take it off.
  • Yeah it happens a lot. Thanks for the code. I’ll give it a try.
  • Flute Man wrote:
    I have a Freightliner chassis and mine has never done that.
    Hi Jerry,
    I guess I overstated the "very" part of my post! When my odo changed, I did some searching and found a lot of threads on different forums, even had one going in our Mandalay group!
    Glad you haven't had the problem.
    Rob
  • I have a Freightliner chassis and mine has never done that.
  • This is a very common problem on Freighliners with the MMDC. If you've got the MMDC, go to the "diagnostics" menu, the password is 8127. Scroll down to an item that says "odometer compare" or something like that. It will show you what what is recorded in the ECU and the IP.
