FIRE_UP
Jan 18, 2017Explorer
Chris's answer is CORRECT! Those are NOT WHEEL SIMULATORS! Those are Accuride 8.25" x 22.5" Alloy wheels. The center cone is held on by that end hexagonal cap. That center hexagonal cab UNSCREWS. Not only that but, it unscrews to the left (normal) for the passengers side and it unscrews the RIGHT on the drivers side. You can use large pliers on it but, you run the risk and are just about guaranteed to do damage to it when using that method. So, a cheap (about $8 or $9 dollar Freightliner cap removal tool is what's needed and kept in the coach for immediate use if and when a tire change is needed on the road.
Scott
P.S. In the picture below, you'll see the large, plastic tool, mounted on the face of the tray that holds all the liquids/sprays etc. That tool is invaluable for that specific purpose.
Scott
