two_travelersExplorerSep 20, 2020Fresh water pump hook up issueJust finished installing a new water pump (Shurflo). Found that it ran but did not pump water. Traced the problem the compression fitting on the input not being tight so there was a vaccumn leak. I s...Show More
midnightsadieExplorer IISep 20, 2020are you any wheres close to canton ohio? might be a few out in the shop.
Related ContentWater pump?Why no hot water?Towing lights issueFresh water tankFresh water tank fill issue
