Bordercollie
May 23, 2016Explorer
Did you actually verify that the low point drain valves are fully closed? If one or both are open partially or not shutting off , water will dribble out the bottom of your rig wherever your low point drain valves are located. Our low point drain valves are located behind a panel in the bathroom wall , hard to see hard to open, harder to close completely. If the valves are not closed, fresh water pump will cycle on and off or stay running.
38,782 PostsLatest Activity: Sep 10, 2026
