Fresh water tank leak? Need temp fix in the next 48 hours.
Just de-winterized yesterday and there is a very noticeable drip coming from the undercarriage, I'd estimate it at dripping 10-20 gallons a day. I turned the water pump off and ran all the lines, and ...
If it does turn out to be a crack I've been told this works well. You will need room to get a torch close to the crack to warm it up a little. Poly Weld
