mcal63775's avatar
mcal63775
fresh water tank odor
Working on draining fresh water tank do to rotten egg/sulfur smell. Once I get tank drained, any ideas what to flush systm with to get rid of the odor? I think maybe a half gal. of bleach and fill tank full? its a 100 gal. tank. Also fearfull that the is going to be a slimey film on the walls on inside of tank.I did not drain fresh tank and left MH sit 6 weeks before using it again. I did nt think it would go stagnant, but it sure enough stinks now. I am working on it now and will check back frequently checking post for ideas and remedies.
  • Ditto x2 on the hose. After RV'ing in Florida I found out what grows INSIDE a hose. Darn right nasty mold. I had to replace them every month or so. Hoses degrade over time, it's good to replace them often. You might have had bad well water at the last CG you filled up at too.
    I'd also double check your batteries to make sure that sulfur smell isn't just drifting down to where you are standing from boiled a boiling over battery.
  • charles wrote:
    I was having that problem on a regular basis. It ended up being the garden hose I was using to fill the tank. I sanitized it with a cup of bleach and fresh water from a new hose. Since using the new hose, I can let it sit for months with no odors. I never drink or cook with the water from the tank but I could not take the sulphur smell, so far so good.
    Nick
    Good advice from Charles;
    I would add:
    As a shock treatment (Sanitise when bacteria and algae are present of suspected use three pints of bleach per 100 gallons.
    Add the bleach to a partially full tank then add water to spread the bleach throughout the tank.
    Run all the fresh water taps until you smell bleach then shut them off.
    Let the tank and system sit for 24 hours them drain. Flush all the water lines with fresh water until no more bleach odor can be detected at the taps.
    Fill and drain the fresh water tank. If the draining water appears dirty, refill and flush until it runs clean and then add more bleach and let it sit again. You won't need as much bleach this time if the stink is gone.
    When you are all done there may be some residual bleach smell but this will not be harmful and will dissipate as you draw from and refill the tank.
    Bleach taste and smell can be easily removed from the water with a carbon filter such as the Brita filter.
    We regularly add a few teaspoons of bleach when filling the tank, especially when we are filling from a natural campground or any source which may not have chlorinated water.
    We use the tank water for washing, cooking and drinking. Drinking water goes through a carbon filter to a separate tap. We don't drink from the tank while in Mexico but we do cook, wash and brush our teeth with it. We also have a three stage filter for filling from sources that may be less than perfect such as wells, and when in Mexico.
  • If you use bleach to sanitize, add the bleach to the hose and then connect to the water faucet. This will sanitize the hose too!
    Was the water stinky when you put it in? If so, drain and rinse.
    If not sanitize with bleach and get a everpure filter for the drinking faucet
  • I was having that problem on a regular basis. It ended up being the garden hose I was using to fill the tank. I sanitized it with a cup of bleach and fresh water from a new hose. Since using the new hose, I can let it sit for months with no odors. I never drink or cook with the water from the tank but I could not take the sulphur smell, so far so good.
    Nick
  • In six years I only put a conditioner in our fresh water tank once and that was probably 5 yrs ago. I just empty and re-fill every 2-3 weeks. I have definitely gone 6 weeks before with no odor or problem (I think it was in the winter....no freezing in Southern California). I like your idea of 1/2 gal of bleach (maybe less)... a little bleach goes a long way! Good Luck!
    MM.
