What is the quickest way to dump the fresh water tank? Is there an easy way or do i have to turn the water pump on and run the water through the taps? I have a 2002 Itasca Spirit 324V Thanks,
I don't believe I've ever seen a fresh water tank that didn't have a drain valve. Look under the rv around the tank area and se if there is a pipe hanging down....usually it's white pic.
