enblethen
Nov 28, 2022Nomad
There is a spring-loaded check valve in most city water connection. There could be a small piece of debris in it causing it to leak.
Remove cap from connection point, if there is a screen type washer remove it. You should see a small 1/8 inch or show prong. Gently push it in a couple times. Using a pencil eraser works.
If this doesn't work connect hose to this connection and try flushing it out.
