jpwiggo's avatar
jpwiggo
Fridge door hindge pin broke off
Domentic NDR1292 - it's a two door model that came OE with my Gulfstream 38' DP
Issue is the main door the bottom hindge snapped off. Broke the plastic around where the hinge pin was mounted in the door itself
Fridge is still working and door stays closed, just to open the fridge you take the entire door off.
I can't get a good look at the damage, as we are in the field, and its a heat wave. I'll be home in a week and can work on it then. I am wondering if others have had this issue.
Is this something that will require a new door? I can't see how to fix this
