Jerry_Amerson1
Nov 10, 2015Explorer
It's a Silhoutte by Dometic Model S819 and it is a 1991 manufacturer. I'm sure the burner didn't have anything to do with it cause all the wiring going into the burner is still good. It's only the wiring at the gas solenoid that is totally burned up.
If I know that circuit the Igniter Control Module gets it's direction from the thermostat and controls the engaging of the Gas control valve and the igniter to start the burner. It appears that the Gas control valve solenoid, which should hold open the gas flow shorted out and in turn melted the two connectors that supply 12v to the solenoid.
I know I'm going to need another solenoid but was concerned about the Igniter Control Module and if it's still good.
Thanks again for your help.
Jake
Jake
38,766 PostsLatest Activity: Jan 10, 2026
