Sooner_Schooner
Mar 29, 2015Explorer
First thing I would check is to see if you are getting the proper voltage to your coach, borrow or buy a tester to see if you are getting 110 volts to your outlets.
I have also seen where a coach was only getting power to one leg of the coach, we turned the breaker off, unplugged the shore line, plugged it back in again making sure it was plugged in properly and luckily everything started working. Won't hurt to try.
38,778 PostsLatest Activity: Jun 05, 2026
