teebarjake wrote:
Hi I need help with a fridge problem. I purchased a 2002 Expedition by Fleetwood last fall. It had a new fridge. We spent the winter in it full time with no problems. On my way home the fuel shutoff switch went bad. we unloaded it and a month later we had it repalced. When it came time to use the fridge the pannel would not respond. I took it in and they reset the pannel, after using it for a week we were on our way home and the fridge shut down again. The service dept says we need to prplace the fridge. I have a problem believing that we don't have some other problem to adress. Can any one Help???
The fuel shut off switch is for the propane at the fill location. When this switch went bad the fridge quit working due to no propane. The dealer replaced the switch and we didn't try to restart the fridge until later and the pannel would not lite up or respond, they then reset the pannel of for the fridge saying it had an over heat error code. But the fridge wasn't used after the propane quit for it to ever overheat, and now it works for a while and then shuts down with the same code, they say it is not leaking freon.
