soren
May 10, 2013Explorer
Alan_Hepburn wrote:Sounds great when you state what SHOULD be done in a perfect world. However, wording your statement as a declaration of fact isn't going to wash. After a few hundreds hours spent, along side of various electrical inspectors, as the perform their duties, I can assure you that a significant percentage of them would of given this job a pass, and jumped in the truck less than five minutes after they arrived. Doesn't matter what their job is on paper, the reality is that they often have a full schedule, a lot of ground to cover, and often no time to be going over another professional's work with a microscope.soren wrote:
...The job of the inspector is to visually inspect the installation to confirm that it meets code requirements, and that it was done to a minimum standard.
Meeting code requirements includes making sure that L1, L2, Neutral, and ground are all connected to the correct terminals - they also make sure that the correct size wire is used based on the requirements of the load and the circuit breaker.
