theoldwizard1
Jun 16, 2019Explorer II
georgelesley wrote:
Now on our second V-10. IMHO a good dependable motor. It likes revs and is noisy when it downshifts in cruise for overpasses, etc. a quick tap on the brakes before hills that will cause the noisy downshift is easy to do. Also learn to use the tow haul feature it really helps. Ours is always on.
Solid, dependable. Not noted for fuel economy.
On older models, I think what you are referring to was called "OD Cancel". It prevented the transmission from using 4th gear.
4th gear with a heavy load (never seen a really "light" Class A !) is fine for flat roads, once you are up to speed. Cancel th OD at the bottom of a hill is simpler than tapping the brakes.
