T18skyguy
Jun 16, 2019Explorer
I have two V10's and the maintenance is much easier than the old 460. The water pump is a simple 4 bolt unit with a big O ring just plug it in and your done. The V10's are strong runners and revvers and both of mine are rock solid. As stated above if you can afford at least a 2017 model motorhome(that would be a 2016 chassis) you get the 6 speed transmission which is also very good. As far as the spark plug issue's, just shop 2004 and later motorhomes.
