Stim
Jun 10, 2014Explorer
Doing it your way you should at least use coil spring compressors!
How ever anyone does it make sure that you smooth down the sharp edge where the hole was punched in the A-Frame.
I have used a die grinder with a stone wheel but a Dremel or even a drill with a stone wheel will work.
38,780 PostsLatest Activity: Aug 05, 2026
