timmac
Jun 10, 2014Explorer
Soak the bags in hot water to soften them up, roll them tight while still warm and use hose clamps to keep them rolled tight smaller than the hole, you will need your wife or friend to help, do not over tighten the hose clamps so not to tear a hole, than use string and tie around bags and than remove hose clamps, spray with oil than push them up through the hole, make sure the motorhome is jacked way up, I did this with new air bags like the ones posted above, it works trust me..
Yes cut the old bags up in springs and remove..
38,780 PostsLatest Activity: Aug 05, 2026
