dougrainer
Jun 17, 2014Nomad
P-30 chassis with the front air bags in the coil springs. THIS IS NOT A RIDE HEIGHT BAG. IT IS A BAG REQUIRED FOR THE WEIGHT OF THE CHASSIS FRONT SUSPENSION. THE BAGS ARE REQUIRED TO BE INSTALLED AND AIRED TO AT LEAST 75 PSI TO GET THE FRONT END TO THE SPEC WEIGHT RATING and alignment and driveability. . Now, if the aftermarket Henderson kits address the increasing of the front end weight rating, then install that type kit. Doug
