Harvard
Nov 03, 2017Explorer
Have you any concern about your current caster alignment. Having too little +caster can manifest itself as "loose steering" and "wandering" at highway speeds.
To maximum the most benefit of the +caster you do have it is best to pressure your front tires to the minimum required pressure for the actual load.
If your toe is not correct you will experience excessive tire wear. The profile of this wear will depend on the camber and pressure. IMO.
