Hikerdogs
Nov 04, 2017Explorer
Dog Trainer wrote:
I recently upgraded my Newmar's F53 chassis with a rear sway bar, CHF and a roadmaster safety steer. After reading many posts it seems that the general feeling among class A owners is that the the alignment ( from the OEM ) is not correct for a MH I don't spending the $$ to do an alignment but I wonder if I am reading these posts correctly. The changes I have made to this point have calmed this coach down I initally had some handling problem when it was windy. I did not have problems from passing trucks etc... Just wondering.
If there are any signs of tire wear or poor handling the first thing I would do is have the wheels aligned. While most body builders claim they align the front end after the unit is complete they do a marginal job at best.
Given the average cost of a tire is about $500.00 it's far cheaper to spend $120.00 on an alignment than $1,000. on a pair of tires.
As a side note Ford does not cover tire damage done by an out of alignment condition. Back in 1999 they put out a technical service bulletin announcing the change. It seems too many body builders were doing a poor job of aligning the front end after the body was installed. They were passing the problems off to the chassis manufacturer.
