deprived
Jul 10, 2015Explorer
j-d wrote:
I think you'll re-use your original ABS Sensors. On ours, the 2002 and 2012 sensors had different connections at the frame end. Remember, don't turn the Key ON before you re-connect those Sensors. Might be good to have the Rotors in place (with their sensor wheels) in place too.
Well, I'm glad you've mentioned this. I wasn't sure if I was going to re-use the sensors or cut-and-solder on the old connectors to the new sensors.
And yes, i am waiting on the bolts from Ford. Austin is kind of a backwater for Ford parts, apparently. The radius bolts are apparently coming in from Memphis. :-(
