ron_dittmer
Jul 12, 2015Explorer III
j-d wrote:If the boss is the only difference, then why change the lower control arm at all? Could I simply change the brakes and be done? Or are there other differences related to the suspension-to-brakes that require swapping lower control arms?
Ron... You have few miles on a very well maintained vehicle. If it doesn't need Ball Joints, then ask Quigley if they'll sell you just the Brakes. Or Brakes and the updated Radius Arm. There is ZERO reason you can't mix the parts. The new axles are the old axles with a boss added to attach a sway bar with end links. Ford even left the bushing holes for the poke-in sway bar they used 1992-2007. Your Roadmaster front sway bar will attach to a new axle just like now. RM and Hellwig show new bars for 2008+, but that's only to take advantage of those "new" bosses.
New Axle with Earlier Hellwig. If you're buying a new bar (and I'd get Hellwig, far less expensive for same thing) then it'd make sense to get the one for later model and connect to the bosses. If my point isn't clear, the bosses are round protrusion, milled flat, with a hole for the end link and there's rust on the surface. The big hole is where the bushing for the '92-'07 bar went.
