emiddleb
Nov 13, 2013Explorer
The OP didn't give a lot of info, maybe I can jump in and help since I have as similar unit...
'04 Vectra has two types of heat... basement electric air/heat pump (Coleman Mach) and aux propane furnaces (front and rear.) The front propane furnace is likely a Suburban SH-42 (40k btu) and the rear likely a Suburban SF-25 (25k btu).
The air, electric heat, and front furnace are all controlled by the same thermostat, most likely a Coleman Mach 6535. The rear has it's own thermostat.
I'd suspect the thermostat, as that particular model has some issues per other threads. The slide switch tends to wear out, not making a good connections. There is a slightly upgraded version that is available and is an easy replacement. Went through it myself.
If you think that's your issue, see this link... replacement thermostat
38,766 PostsLatest Activity: Jan 10, 2026
