Mike_and_Pat
Nov 14, 2013Explorer
I had the same problem this year with my 04 itasca meridian. The suburban sh42 furnace would not do anything. It ended up being the circuit board. I got a replacement from dinosaur boards for just over $100 and the change out was easy once you remove the furnace for access. If yours is like mine the access is next to the hot water heater remove the screws that hold the cover plate in place and then disconnect the propane line and then 1 screw for the furnace and out it comes. unplug the wiring harness and move the furnace to a work bench.
38,766 PostsLatest Activity: Jan 10, 2026
