Here you go grumpy.
I had it custom made to go in the receivers for the tow bars. I put a hub cap on the front to make it look a little nicer. No idea on cooling so far as I don't have a scan gauge yet. The idiot gauge hasn't changed inside but no way to check the tranny temp until I get the scan gauge on it...which will be next spring now as it is in Canada. I'm sure There is some air restriction but a lot of air still gets by it. I might make an inconspicuous scoop underneath it to direct the air a bit. With my long overhang it made a difference to the handling/bounciness. Hope this helps.
